T56 won't go into reverse Ok, so today I was driving around all gears worked, including reverse. I went to work for like 10 hours, and my reverse didn't work, I had to push my car backward out of the parking space. I drove around for a while and my gears became harder to shift and reverse still didn't work. What's wrong? Can anyone help, I really hope I don't need a new one. (Yes I posted this exact thing in the manual section, sorry but this car is my DD and I need info asap, sorry.) |
sounds like something in the hydrolics for the clutch. |
Originally Posted by 99345hp
(Post 9896284)
I let it set again and it works. Weird, anything I can do to prevent that? |
check the wiring under the car. make sure the rev lockout solenoid is connected good. if you have longtubes make sure the o2 wires arent getting burnt. i had an o2 wire touch the header and it popped the fuse under the hood the worked the rev lockout solenoid and the o2`s. |
^^^^check rev lockout selonoid but if other forward gears are hard first check the slave cyl and the reservoir. |
Check the Wiring and the Reverse Lockout Solenoid.. then start looking into the Hydraulics. |
| All times are GMT -5. The time now is 10:51 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
