Has anyone replaced JUST the 3-4 Fork?
The reason I ask, is I'm looking to sell the SS and it has only 26k on it, the tranny shifts smooth w/no other problems except 3rd started popping out of gear when decelerating.
The fork is 40+ bucks, and I don't want to sink a ton of money into a tranny when this seems to be the only problem.
Has anyone replaced just the fork? Is it difficult for DIY, or is it expensive for the trans shop to do? Does it still require a full teardown?
I'm trying to weigh out all my options, thanks for any help.
If its poping out of gear thats the Syncros going bad. Im guessing it would cost quite a bit to take the tranny apart, you might as well just build the whole thing. Im sure its not cheap to take a tranny out of the car and get it taken apart.
26k miles though? Wow, I have 31k on mine, makes me think Im on borrowed time.
i ended up putting the steel shift fork in mine and a new syncro.. it was a pretty easy job.. just keep track of everything as it comes apart..
mine had 120,000km and the only reason i touched it was because it was poping out of reverse when i bought it.. if you know how to drive stick and dont grind the heck out of the gears you should be ok...
It could well be that you could fix the prob with a fork change. If the prob is due to the fork wallowing at the rail ( the common 3/4 fork problem). If you swp this out along with good pads. If it has been happening awhile, you may have secondary probs there. You still have the in& out & TD( yep a full teardown) labor but if thats you, its just sweat & time.
it might 3/4 synchro keys or 3rd gear itself you have to get in there to find out. I thought my 3/4 fork was bent but it was the keys i put in a steel fork and billt keys
read greysteel's "how to" above and go for it
