exhaust shops in oklahoma
Headers install pretty easy depending on the brand. Most 1 3/4" headers install with minimal issue as long as you can get the front of you car 2-3' in the air to install from the bottom. Expect to take about 6 hrs for your first set. Get the back bolt on the passenger side from the bottom.
I use a stubby rachet and it makes it easier for me.
It might also be a good time to replace the plugs while you are there.
Get new 02's, I never had any luck with the extensions. Part number Bosch 13111 I believe are the ones that are long enough that you do not need 02 extensions.
Use GM MLS gaskets, some people just reuse the ones they have.
Use your original bolts to bolt header to the head.
Any other questions. just ask.
