H/C WS6 vs. turbocharged Integra GSR
Old 12-09-2008, 02:51 PM
  #81
25psi's Avatar
Originally Posted by southern69chevy
So your saying that the old saying "There is no REPLACEMENT for DISPLACEMENT" is totally false and not true???????
There are alternatives to supplement displacement(FI and rpm). No one on this site makes more hp than an F1 car via N/A. They make 800hp from 3.0 liters of displacement and this is due to high rpm capabilities.
Old 12-09-2008, 02:57 PM
  #82
25psi's Avatar
Originally Posted by ChevyWeatherman
Do you know the definition of power? Hit up wikipedia or something and get back to us.
If you can not understand the concept that I gave you, then I do not know what else I can do. Let me see if I can rephrase this for you.
The only way you can make hp, is to increase VE at redline. Generally, when increasing displacement, you move the torque output to the left. Meaning you are increasing torque output sooner than before. Granted, if everything is the same(stock cams, redline, heads, etc....) and there's not a sufficient amount of volume going through at redline, you will not make more hp. The only way to make more hp is more torque throughout a higher redline.
Old 12-09-2008, 03:00 PM
  #83
25psi's Avatar
Here's an example I posted earlier. You will notice how you can make more torque down low, but more torque higher in the rpm range means more hp.
(3 ft/lb of torque @ 2 RPM) / 5252 = .0011424 HP
(1 ft/lb of torque @ 8 RPM) /5252 = .0015232 hp <<<<<<<< more hp.
Old 12-09-2008, 03:25 PM
  #84
OUTLAWZ RACING's Avatar
Ummm.. A 250k 3.0 and its only that size for weight and space and I think A f1 motor is a work of art. Push rod vs f1 stuff is not a good comparsion bro. In the real world with guys that have 9-5 jobs and save up for **** increasing displacement is a nice bang for the buck instead of no2.
Old 12-09-2008, 03:26 PM
  #85
Oh And I think a single F1 team has a bigger budget than GM or Ford, And a way smaller crowd to build motors for LOL!
Old 12-09-2008, 03:28 PM
  #86
25psi's Avatar
Are we gonna pick and choose what argument we want? Honda's can rev to 12k with the proper valvetrain. Skylines have been known to make power up to 12k rpm as well. The point I am trying to make is, there are other alternatives to making power.
Old 12-09-2008, 03:30 PM
  #87
True man true. But why nevermind bro have a good one LOL!
Old 12-09-2008, 04:52 PM
  #88
JD_AMG's Avatar
The only way you can make hp, is to increase VE at redline. Generally, when increasing displacement, you move the torque output to the left. Meaning you are increasing torque output sooner than before. Granted, if everything is the same(stock cams, redline, heads, etc....) and there's not a sufficient amount of volume going through at redline, you will not make more peak hp. The only way to make more peak hp is more torque throughout a higher redline.
I think the problem with your argument is your wording, Ive put in bold what you should have said.
If you make more torque, you automatically make more power (notice I did NOT say you make more peak of either.)
Old 12-09-2008, 04:57 PM
  #89
JD_AMG's Avatar
They are 3.0L V10 engines because the rules state they must use a V10 engine with no more than 3L of displacement.
Yes, very right, alternatives to increasing displacement, not replacements...
Old 12-09-2008, 06:47 PM
  #90
southern69chevy's Avatar
Old 12-09-2008, 06:51 PM
  #91
25psi's Avatar
That is not peak if you make more power throughout the entire powerband.
Old 12-09-2008, 06:59 PM
  #92
master of the "jack"stand
ChevyWeatherman's Avatar
You have some good ideas, but you are missing some of the valid points you are clearly incorrect about. I will give up the conversation with you because it seems like I am talking to a bot. And a current F1 engine is 2.6L V8, not a 3.0L V10.
Old 12-09-2008, 07:10 PM
  #93
lemons12's Avatar
this thread sucks...
nice kill op
Old 12-09-2008, 07:25 PM
  #94
25psi's Avatar
That further proves my point, that you can make power with rpm's.
Old 12-09-2008, 07:32 PM
  #95
lemons12's Avatar
this thread sucks..
Old 12-09-2008, 07:35 PM
  #96
Originally Posted by lemons12
this thread sucks..
way to contribute to the suckness.
Old 12-09-2008, 08:00 PM
  #97
lemons12's Avatar
i figured if i did that enough it would get locked sooner than later..
PS. this thread sucks....
Old 12-10-2008, 09:56 AM
  #98
StangAddict's Avatar
L98
Lt1
LS1
all share the same displacement. The reason why the LS1 is significantly faster is due to a higher redline to take advantage of hp and gearing.
HAHAHAHAAHAHAHAHA!!!!!
Guess it has nothing to do with the higher flowing heads and higher flowing short runner intake?!
Old 12-10-2008, 12:41 PM
  #99
25psi's Avatar
Again, that's not the point I was trying to make.
The three examples that I listed all make about the same amount of torque and are nearly identical in weight. My contention is that torque is not important as speeds increase. Furthermore, my illustration constitutes that a higher redline is needed to supplement the additional VE from a stroker in order to make more hp(the reason why the LS1 is faster.) and take advantage of gearing.
Old 12-10-2008, 01:20 PM
  #100
JD_AMG's Avatar
Reread your own post
"The only way to make more hp is more torque throughout a higher redline."
Torque is never "not important." What you are confusing is that low end torque is less useful, because you are not in that RPM range. However you are in the higher RPM range, where the torque there matters.
The LS1 makes more torque all over, that's why its quicker, not because it has a slightly higher redline. Even if the LS1 switched at the same RPM as the other two engines it would still be quicker, because its still making more torque at those RPM ranges.
https://ls1tech.com/forums/10616577-post75.html
