air pump hose and pump
What are you supposed to do after installing lid with air pump hose? It does not reach new lid, plus no place to hook it up. It used to go to air box baffle but that gets removed with lid installation. What are affects if I disconnect hose and unplug wiring to it? Why is this not mentioned with lid instructions? I never have seen anyone else post anything with this problem.
lol. The 2000+ have to use a small k&n to connect to such device. You can buy them at pep boys or nopi if you want the ricer look.
I bought my lid from TSP, they asked me what year i had, and sold me the K&N mini that fits right up to avoid any problems.
SF, if your lid does not have any fittings for an air setup, then look into the !air mod. its completely removing your air system. it won't have any negative effects on your car, plus you will lose something on order of 8-10lbs easy off the front end, AND clean up the engine bay quite a bit. its an easy mod, you can buy the block off plates for the manifolds for like $8 from many sponsers, or from your own(not difficult). if your lid DOES have a fitting for the air, then as sam said get the k&n mini.
btw, you can find a !air walkthrough at installuniversity.com
just leave the pump hooked up and active. it doesn't care where it's pushing air to as long as it can. this way, u can remove the ugly stuff without expensive tuning to prevent a code being thrown. enjoy.
Originally Posted by B-MAN
Ls1 edit will let you delete the air pumps for a gain of about 4-7 HP.
Originally Posted by Blue2002SS
How can you gain 4-7 hp from removing the air pump? it is electric. the onlything you will gain is a little weight reductions
It amazing how much a excess heat in your engine bay can affect power gains
I hope this explains what you are looking for.
