newbie needing advice on a cam
read the cam sticky under internal eng gen 3, but before you "stick a cam in it" think about the rest of the mods you should get (as the last poster mentioned). also we need to know is this a daily driver you need a good idle or a race car with a choppy uncivilized idle? how high do you plan on revving the engine 6k 6.5k 7k? upgraded SPRINGS are a must with a bigger cam. first mods should be air lid, cat back, headers (if legal/no emmission cks) suspension LCA lower control arms, SFC sub frame connectors, panhard bar, then id get a ported throttle body , ls6 or better intake (i forgot your yr car) TUNE is a must. then pop in a cam and ls6 heads. now your good to go although your wallets a little lighter! cheers! ps if you remove your stock cats dont throw away, they have platinum and are worth $$.
