Fuel filter question.
LS1Tech Administrator
Received 1,486 Likes
Originally Posted by LS1LT1
Every 10k miles, 15k max I would say.
It's easy to change, it's a quick disconnect type setup....
Originally Posted by LS1PoweredZ28
I have heard that you should let the pressure out of the fuel system. Do you have to do this? What is the best way to let the pressure out?
Kevin
Kevin
its quick and easy, just let the car be cool and dont even worry about the depressurizing valve; just remove the gas cap and that will do it for the car if is cooled down. just make sure you have some shop rags (fuel leaks from the lines even with it depressurized) you need some needle nosed pliers and a 14mm wrench... or maybe its 15mm. I dont remember just use that with the craftsman wratchet wrench and its a sinch.
-JOSH
-JOSH
I change mine whenever the fuel pressure at WOT drops. However, except for those rare occasions that I run my LS1 on pine tar or turpentine (man does that stuff have some octane!), I haven't manged to reach this point.
Where is the fuel filter located?
Any particular brand better/worse than another?
Edit: I just found this link.........nevermind!
http://www.installuniversity.com/ins...lacement_1.htm
www.cantonracing.com/fuel.cfm#
Originally Posted by sawedoff
Yes, you will get what you pay for. That's why I went with a Canton Racing GM EFI fuel filter, part number # 25-909. It has a billet case that can be disassembled when you need to inspect or replace the element. It is designed to work in the stock OEM lines and even uses the clips. It is much bigger and flows up to 90 gpm. I discoverd these because I noticed that the car didn't feel its' usual self when I replaced the fuel filter with a parts store brand. I did a fuel pressure check and was able to deduce that it was the fuel filter. These cheap OEM style filters are "iffy" in the quality department. The majority are made on low bid in a foreign sweatshop.
I think there's a big difference between it and say a 'no name' brand or even a Purolator etc...like Colonel said, OEM name brand (ie: Motorcraft for my Mustang) fuel filters is all I put in my cars, unless of course a whole new fuel system (blower/turbo/crazy nitrous set up etc.) is required.
While I agree that the Canton is a nice piece that will probably flow better (especially with some serious internal/FI mods going on up front) I think the key was that your car "didn't feel it's usual self" after replacing the stock one with a cheapie parts store filter...did you try/test an actual AC Delco/GM replacement one as well?
The one that I replaced the OEM unit with was a Delco/Gm unit. I really don't think it's realistic to do a lab test on this. I was looking for a stable quality unit that would be consistent each time I replaced it.Plus, I can inspect the element by disassembling it. I can't with the service replacement types. If I were to do any enhancements to the pwertrain, I have the confidence that fuel filter is up to par on the task. The GM stuff is also made on low bid basis as well, and corners are cut. Look at their service replacement oil filters and such.
I might consider it.
"and even if it's only slightly it still has to flow better I'm sure."
I wouldn't just assume that. Maybe it does, maybe it doesn't. No way to know without flow testing it. You might be surprised to find just how good the stock filter really is. At 525 RWHP I found the stock fuel rails to be a restriction...but not the stock fuel filter.
