spark plugs and wires
Old 12-16-2003, 03:35 PM
TRAGIC's Avatar
Question spark plugs and wires
I just ran the vison premier (engine analyzer) on my car and it reads that i need new spark plugs. I was wondering what plugs would work best for my car. I bought AC Delco (stock) plugs and have not yet installed them because a friend of mine swears the NGK tr55's are better. Any advise? i have a 98 TA ram air A4. My basically stock. Also...I want to know the max resistance on the stock spark plug wires to check if mine are still good. Thanks for any help!
TRAGIC
Old 12-16-2003, 04:11 PM
boos2's Avatar
The NGK's are good. I run the TR55's, but the TR5's would suffice.
Can't help you as far as wire resistance.
I run Taylor 10mm. The MSD 8.5 mm is another popular choice of aftermarket wire.
Old 12-16-2003, 04:39 PM
onebadz's Avatar
Like boos said, I would go TR55's gapped at .050 with MSD 8.5's. Good Luck
Wes
Old 12-16-2003, 06:42 PM
jrp
SN95 Director
jrp's Avatar
ngk tr55's and oem wires.
Old 12-16-2003, 06:58 PM
sawedoff's Avatar
For plugs, you can try the Bosch Platinum +4's. I use them. For plug wires, it's simple, get Magnecors. I also use these.
www.magnecor.com
Old 12-16-2003, 10:44 PM
NKAWTG...N
StoleIt's Avatar
anyone heard of nology? hot rod or chevy performance had mad raves about them...
Old 12-16-2003, 11:00 PM
1BadAzzWS6's Avatar
I used to use the NGK TR55's. I changed to the TR6's when I started using a N20 kit. For the plugs I went with the Taylor 10.4mm Thundervolt wires.
