What If you cant avoid the water box?
Ok, @ the tracks I have been too it is almost impossible to avoid the damn water when getting on the track. I have new tires, should i burn them down to get the water off?
STF Veteran
Same problem at my track. The water's in a recessed speed bump from side to side, and can't get around it cause of the concrete barriers.
All you can do is spin'em clean, but not all that much water gets on your tires from just passing through. The guys with slicks usually spin'em in the water a little to get more water on their tires, then heat'em out of the water.
your only choise is to heat the tires real good, and burn off any extra water, after that jerk the car foward to the staging light to shake any extra water off from under your wheel wells
