Are stock rods bad?
the main concern about stock ls1 rods is the rod bolt.if you are upgrading with a crank and pistons a aftermarket rod is the safe ting to do.a longer rod helps with your rod to stroke ratio,1.5 is ok 1.6 will make a little more power and less thrusting on the out side bore wall.
