rebuild? i bought my 98 z28 last December and i think i just got into a mess the car runs okay with the maf unplugged but idles to high ive been asking around and no one knows whats wrong with it. im pretty sure theres something wrong with the drivetrain also. so i was wondering should i try to rebuild it or should i just sell the car? and if i should rebuild it what do i need and how much will it cost? |
or is this a problem i should just try harder to fix? |
Sounds like it is in limp in mode might want too check the o2 sensors |
SES light on??? What part of the drivetrain do you think is bad? Why? |
Originally Posted by lt56026
(Post 13835471)
Originally Posted by SOMbitch
(Post 13835989)
First thing you need to do is replace both o2's that the codes are calling for they alone can make the car run like crap. Then the maf is most likely dirty go to the store and buy the special crc maf cleaner and follow the directions on the back. This should fix ur motor issues as far as the axle goes take it out and check to see if its bent. |
Originally Posted by redbird555
(Post 13838452)
if you leave the maf unplugged it is going to run like crap at WOT. If the TPS is bad that could cause it also to run really funny. If you have acess to a scanner use it to make a graph of the TPS as you open and close the throttle. If any bumps or hiccups, then the sensor is bad and replace it. Any one of those sensors being bad will make the car run like dog poop. If you fix your sensor problems the car is worth a lot more. |
borrow the TPS sensor from your friends car and put it on yours to see if that is the problem. |
Originally Posted by garygnu
(Post 13840298)
Originally Posted by JcsBlk98z28
(Post 13841237)
just did that and its not that im thinking i should replace the o2 sensors and take it from there do yall think doing that willl make it run better |
Originally Posted by Finkledbody
(Post 13841385)
Yes.. |
correct, the back two are for your cats. |
© 2024 MH Sub I, LLC dba Internet Brands
