Caliper Frozen?
Caliper Frozen?
Ahem. I ain't always the brightest bulb in the box, but this weekend I went ahead and swapped pads/rotors. I also used a mityvac to bleed about a QUART of green/black fluid out of the system
My fluid procedure was this: Fill res. to the top, cap it, and bleed out til it reached the max fill mark. It NEVER got lower than that on fluid, bleeding 3/4 corners. (The Driver's side front, the bleeder screw was rusted and stripped.)
So, I test drive the car. I did the basic pad brake in, drove about a mile and a half, got to ~35, and made a moderate, steady stop. I did this 7 times over that mile.
The brake pedal STILL has not recovered its feel, and I had to pump a little bit.
I pull back up to the house, smelling warm brakes. It's not BAD, but it was enough to make me triple check.
Sure enough, my driver's side rotor up front looks.... blue.
There is no leaking fluid on the rims, at all.
So, here's what I got...
-No pedal pressure after 40+ pumps with the car running, fluid level full.
-extremely warm front rotors
-No fluid leakage
-No brake warning lights
Is there something on the ABS system I need to check/reset? I will buy calipers no problem, but I want to make sure that's my issue before I **** off the wife.
-No fluid leakage
it could be that the pins are frozen. Check the boot on the piston and pins for damage. Then take some lube to the pins. If the rotors went blue they are probably shot lol. See if there are any heat marks. Did the pistons slide back in when you put the c-clamp on them?
I've ordered a set of calipers.
