High Idle on startup (3000 rpms)
Old 12-06-2010, 12:58 PM
ISMELLRICE's Avatar
Default High Idle on startup (3000 rpms)
Hey guys ive had my new 99 trans am for about a month and a half now and since the first day ive had it it idles about 3k rpms and drops after about 10 seconds...now it doesnt happen all of the time just maybe 3 times a week but it still freaks me out b/c i do have an oil leak*maybe its a vacuum line and thats why it idles that way* but it only does that at idle...
there is also oil leaking from somewhere and it gets on the oil filter, plug but mostly just on the left side*drivers*
i cleaned the iac but it did nothing to help, should i just buy a new one?
thanks
Old 12-06-2010, 01:01 PM
BStowers023's Avatar
Could be in the tune?
Old 12-06-2010, 03:28 PM
Head Hunter's Avatar
What all has been modified?
Old 12-06-2010, 09:31 PM
ISMELLRICE's Avatar
Nothing, the car has 89k miles and is all stock, I think if it was in the tune it would do it 100% of the time...
Old 12-07-2010, 06:33 AM
garygnu's Avatar
try cleaning your MAF.check all of the PCV lines,one line is connected to the left rear valve cover.
Old 12-07-2010, 03:42 PM
sjsingle1's Avatar
can you say........vacum leak
Old 12-07-2010, 03:46 PM
metalmilitia606's Avatar
Yeah I say vacuum leak somewhere too.
Old 12-08-2010, 02:58 AM
ska4life07's Avatar
Vacuum leak or check for loose spark plug wires
Old 12-08-2010, 07:44 AM
ISMELLRICE's Avatar
Thanks guys ill check it this weekend
Old 12-12-2010, 09:21 PM
Garr's Avatar
I had a vacuum leak on my 94 and it did the same thing, i duct taped that bad boy and problem solved haha
Old 12-13-2010, 07:17 AM
ska4life07's Avatar
Niiiiiice! Good TEMP fix :p
Old 12-13-2010, 07:52 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Vaccume Leak, im willing to wager that one of the lines in the back are disconnected. I took my FAST 90/90 set up off and went back to a LS6 and I had a major issue with a fuel line which long story of the short made me rush to throw it back together in 15 minutes and it had the same thing.
But being early January and I ran the car back to it's storgage unit, I did not look at it for about 5 months and only noticed when driving that I had no selector for vents or really any HVAC.
Well, knowing that I messed with something. I tore it back off to find I pinched the hard line and the 3 ended vaccume fitting was not even on. So I had to cut the damaged line, replaced with a rubber and reinstall the intake.
Instand fix, HVAC works and all is well. I thought it was the IAC but as long as its clean and you did not damage it, then I would consider that. I would say think about the MAF but in open loop the MAF is not a consideration for the PCM.
Old 12-13-2010, 02:19 PM
ISMELLRICE's Avatar
I'm going to have to wait until I do my long tubes in 2 weeks, to check behind the engine...suck man I hate the smell of the oil hitting the exhaust...and its gotta be that vacuum line in the back I think
Old 03-06-2011, 10:49 PM
starfishy's Avatar
Did you ever find the root cause?
I had the same problem today and refastening the loose rubber hose on the A.I.R. check valve seems to have fixed it. Will have to see tomorrow whether this is really the fix.
Old 03-13-2011, 12:29 PM
mikedamageinc's Avatar
Check vacuum lines and do an idle relearn. If not that maybe idle air control valve.
Old 03-13-2011, 12:50 PM
ROCKETWS6's Avatar
Does it crank kind of slow?when my battery was going it would crank and rev to 3,000 and then idle down it would only do it if it was sitting for awhile
Old 03-13-2011, 12:54 PM
BrdofPry's Avatar
Went through the same issue, ended up being a Vac. leak..
Old 03-13-2011, 01:05 PM
joesscamaro252's Avatar
Vaccum leak. Check the PCV hose behind the passenger head where the hoses merge.
Quick Reply: High Idle on startup (3000 rpms)
