firebird/trans am rear end swap??
Hello guys, new here and need help with my 99 TA. I have some chattering in my rear end while driving, and of course, the rear is leaking a little. I'm going to pop the cover off and put a new gasket on and service it up with fresh oil first, but if that doesn't make a difference, i'm going to get a new rear end, instead of wasting the time and money rebuilding this one. I'm not planning on boosting the HP up too much, or I would just buy a 9". My question is, can i take a rear end out of a 98-02 firebird/camaro(v6) and bolt it in??? what cars came with what gear ratios, etc??? Thanks alot guys.
Hiram
If you have an auto and aren't planning on making much more than stock power, I wouldn't spend the money on the aftermarket rear unless you race a lot. Buy a rear end girdle and the thing can last. People on here act like they are made of glass.
My '97 Firebird A4 auto V-6 had the 2.73 gears in the rear and did the one wheel burn-out, if you could get it to spin, that is.
My '01 Firebird A4 auto V-6 came with the 3800 Performance Package which had the 3.42 Torsen rear normally found in only the V-8 manuals but only offered in the automatic for the V-6 PP. Not the 3.23's in my current TA, 3.42s. The 3.42 was too low geared for a A4 but was pretty quick off the line for a V-6.
"The 3800 Performance Package added P235/55R16 touring tires, Zexel Torsen II Limited Slip, uplevel steering, dual exhaust outlets and 3.42:1 axle ratio (available only with the automatic transmition)" From the Standard Catalog of Firebird (Gunnell)
swapping rear ends
if im doing a clone conversion on my 99 firebird...do you have to change rear ends? or will the driveshaft from a v8 trans work on the v6 rear end?
