Rocker Arm bolts sealant?
Hi,
Im in the process of replacing a bent pushrod (from suspected excess RPM) & noticed on the bolts holding the rocker arms an orange coloured substance on the tapered part/underside of the bolt head.
Is the sealant of some kind or just paint?
Thanks.
Thanks.
Here's a pic of my P/P 317 heads. Look to the upper right side of the intake runner. http://mycarpics.shutterfly.com/190
See the hole, that is the intake rocker arm bolt hole. The material that was removed during the porting process opens up the bottom of the "blind" hole.
No, the heads are standard. The ony mods are the ignition kit, the carburettor & the exhaust.
It replaces the center section of the rocker arm with a better design and bearing. Some people have found their oil drain plug magnet covered in little needle bearings from a failed rocker. It's just a good bit of insurance when you go with bigger cams and stiffer springs that are stressing the OEM rocker.
