Plugs and wires
Pontiacerator
Originally Posted by VIP1
Why would their be a weaker spark? There are just more paths for the spark to follow.
--vIP1
--vIP1
I like running the MSD 8.5 wires (40 ohms per foot), and NGK TR55's gapped at .055. The wider the gap the hotter the spark. Run as wide a gap as possible without getting misfires. I'm happy at .055 because the gap will widen over time & I don't want to change plugs as often.
.045 is better for cars running N2o.
as far as the plugs go the whole purpose for the 4 prong is so that when one prong gets burnt up or carbon build up the spark has 3 other possible paths to ground, it just helps the plug last longer, the spark doesn't split 4 ways it just takes the path of less resistance to ground. and for the comment before about the platinum plugs, they aren't to bad on a n/a engine but don't use them on turbo or supercharged engines, probably not a good idea on high compression either because the platinum heats up and stays hot, it takes a while to cool down so if you have a beefed up engine you could be at risk of detonation because of the plug being so hot it could ignite the a/f mixture in the cylinder before it is supposed to. at least that is what i have read in many magazines and heard from fellow mechanics.
Copy & Paste Moderator
Originally Posted by RevGTO
What convoluted path would the charge have to take to make spark with four prongs.
--VIP1
The stock wires are pretty damn good for a mild engine. I'm still running stockers on my H/C/N package, though that may change shortly. I use TR6s gapped at .038 for the nitrous..
