Can someone set the record straight?
Old 10-07-2012, 12:44 AM
Powe's Avatar
Default Can someone set the record straight?
I've been reading all night about LQ4 and LQ9 engines. I have one and I'm wanting some more hp before I put it into my 67 Nova. I'm on a budget (like everyone else) and I read that the Ls3 stock heads will work with the lq4/9 block but I have to watch my PTV clearance.. I PM'd a vendor on hear and he told me to stay away from them b/c I'll lose my hp/tq down low. He mentioned to go with the ported 243 heads. At $650 for the pair of LS3 heads it just seem like a sweet head with a custom cam. I really don't want to mess with the bottom end, so this is either a go or no go for me. I'm looking for the 450rwhp range with heads, cam, ls3 intake, and headers.
Jason
Old 10-07-2012, 07:28 AM
MonmouthCtyLS7's Avatar
Jason
You don't need LS3 heads to hit 450 rwhp, ported the stock LQ heads will get you there with the right cam combo. Either route you decide it will cost about the same. The LS3 setup might give you a few more ponies w/ the better heads.
Old 10-07-2012, 08:48 AM
Powe's Avatar
Thx for the reply. But I haven't seen any ported ls heads under $1000? If they will be about
the same in performance and the ls3 heads are cheaper and will work fine with no loss in performance then why not use them? I was told that with anything under a 4.1xx bore the ls3 intake runner and valves are just to large for the 4.0 bore block.
Old 10-07-2012, 09:20 AM
On a small bore motor I think your better off w/ the 243's/317s. Apparently the Vendor you contacted felt the same way. I would pick up a complete LQ4/9 send the heads of to AI or TEA for porting then top it off w/ a Fast...Sounds like your bench building, a heads/cam build is the last place you want to nickle and dime.
Old 10-07-2012, 10:21 AM
garygnu's Avatar
the big valves of the ls3 head mite hurt flow on a smaller bore .check Texas Speed for heads,ls6 st 1 or 5.3 st 2.5.you could sell your stock heads to off set the cost of ported heads.
Old 10-07-2012, 02:08 PM
Powe's Avatar
Well i found out that I actually have a ly6 engine which I believe comes with l92 heads? Now I need to figure out if I should keep the vvt or not?
Old 10-07-2012, 03:53 PM
TransAmatt99's Avatar
Find a used set of Patriot cnc ported heads, or keep what you have and get a vvt cam from comp cams. Also an ls3 does not have a 4.1xx bore size.
Old 10-07-2012, 04:02 PM
Powe's Avatar
I know a ls3 doesnt have that size bore
Old 10-08-2012, 04:56 PM
spordee1's Avatar
Default pics of L92 HEADS
These are pics of new L92 Heads for $600. plus $25. shipping.
Attached Thumbnails Can someone set the record straight?-1075-012.jpg   Can someone set the record straight?-1075-013.jpg   Can someone set the record straight?-1075-014.jpg   Can someone set the record straight?-1075-015.jpg
Old 10-08-2012, 07:41 PM
Sales@Tick's Avatar
You're getting good advice here in this thread, but since you already have them we will just work around it.
No biggie
Quick Reply: Can someone set the record straight?
