Need some second hand opinions/advice
Looking into upgrading. Wondering if this is a good choice. Car will be a DD, I dont care too much about gas mileage but I dont want to rape it either I am looking to gain at least 120HP/100TQ. I already plan on installing a Volant Cold Air intake and a smooth bellows.
Car is a 02' 100% stock M6 T/A Ws6
Unsure of what brand and size:
Stroked LS1 to 383 or > with 4" or >
Cammed
Cut out
Borla, or Magnaflow, or Flowmasters?
Chip
Throttle body 90mm or > and Fast intake (LS6 or what?)
Spec 2 clutch? Ive heard they stall easily.
Cammed
Cut out
Chip
Stroked LS1 to 383 or > with 4" or >no need for your goals
Cammed-228R, torquer V2, custom grind
Cut out - it helps
Borla, or Magnaflow, or Flowmasters?Borla or Madnaflow. Flowmaster is a no no.
Chip-No chip. dyno tune or mail order tune at the minimum
Throttle body 90mm or > and Fast intake (LS6 or what?)used fast 90/90, 85mm MAF
Cut out - it helps
you should also look into getting a set of used 243's and get them ported and polished and you would also need to upgrade rearend to a S60, 9". or 12 bolt. Anything but the stock 10 bolt.
https://ls1tech.com/forums/new-ls1-o...anna-fast.html
https://ls1tech.com/forums/generatio...-me-first.html
http://ls1tech.com/forums/generation...cam-guide.html
https://ls1tech.com/forums/generatio...e-posting.html
https://ls1tech.com/forums/manual-tr...d-threads.html
https://ls1tech.com/forums/gears-axl...ere-first.html
Cammed
Cut out
Chip
Cammed
Cut out
Chip
consider getting a 383 rotating assembly to use with you current block,if you have a good engine builder close by.look at some TSP PRC 225 cast heads.get a fast 102 intake with a custom cam.you mite make 475+ rwhp with the right cam,and a good tuner.
LS1Tech Premium Sponsor
For the power you are looking for, I would start with the basic bolt-ons (long tube headers, full exhaust, and a lid). I would follow with cylinder heads, camshaft and intake manifold. Your transmission and rearend will probably need to be tended to these items to handle the power. Lastly a good tune. With the correct combination you can have a powerful daily driver that can still be easy to drive.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
To reemphasize what was said earlier, canned tuning(plug and play tuners) is not an option when you start modding. EFI live or HP tuners is the way to go with a reputable tuner.
