Low LSA cam question
Old 10-29-2012, 04:37 PM
TyCZ28's Avatar
Default Low LSA cam question
im trying to pick a cam for my car but nobody seems to be able to help me any..
i have an 88k mile 98 LS1 and im going heads cam intake but not touching the stock shortblock AT ALL. its going to have 5.3 heads so i can get a compression bump and boost my low end torque and an LS2 intake and 92mm throttle body and a 92mm LS3 maf (no i dont want an LS6 because i want to run 92mm from the lid to the intake and i find it a waste of money for a FAST for a street car no offense to those who have one)
so im going to have the rev limiter at around 6300 so i dont have to worry as much about a rod bolt failure
i want a decent size cam to make 425+ at under 6300 rpm... so i can shift around 6100-6200
one im looking at makes 440rwhp at 6400 rpms on a 113 LSA
if i do that cam as a 236/236 .602/.602 at 110 LSA would it drop my powerband enough to hit peak power before my rev limiter??
if i can get it to make peak power at around 6k ill be set...
Old 10-30-2012, 10:00 AM
TyCZ28's Avatar
nobody???
talked to Tom at New Era and seems like the street sweeper on a 111 or 110 lsa would work well for my needs. the 111 peaks at 6300 so the 110 should be a little lower correct?
Old 10-30-2012, 10:08 AM
bww3588's Avatar
Torquer v3 on a 113 would bring power in early, and carry it all the way to 6500, probably peaking a little earlier. However, the Ls2 intake will choke it off so it might peak earlier. The ls6 with a stock tb would be a better choice with 85mm from that to the lid...
Old 10-30-2012, 02:47 PM
TyCZ28's Avatar
the thing is i dont want my RPM's anywere near 6500. i want to shift at 6200 the absolute latest...
also the RPT cnc machined LS3 maf housing only comes in 92mm or 102mm and i dont think i want to bottleneck it down from a 92 to an 85
heres the streetsweeper cam
Old 10-30-2012, 03:19 PM
TyCZ28's Avatar
REALLY liking the looks of the Speed Inc SI5
Old 10-30-2012, 04:47 PM
99Bluz28's Avatar
IMO, get the LS2 intake ported it needs it!
Any Idea what the ICL is with the SSHT with a 111 and 110lsa?
I'd go probably go with a 107 ICL.
With a 230 or larger intake duration a 110 or 109lsa and a 106 ICL.
I also wouldn't larger than a 231 on the intakes side.
Old 10-30-2012, 08:22 PM
TyCZ28's Avatar
the streetsweeper on the dyno graph i posted is a 236/240 .630/.615 111 LSA
this is the mod list for the car it was in
stock LS1 long block
Street Sweeper cam
American Racing 1 7/8" headers
New Era ported throttle body/ LS6 intake
Tuned by Mike@newera
426RwHP 387wTQ
im going to be running some mildly ported 5.3's instead of the perimeter bolt 98 heads
The speed inc SI5 is 231/237 .589/.595 112 LSA
the dyno was stock longblock LS1 LS6 intake and longtubes through an A4
Old 10-30-2012, 09:35 PM
The Scammer Hammer
dr_whigham's Avatar
I'd go with the street sweeper HT, first and foremost.
Get the LS2 intake out of your head. They don't flow anywhere near what an LS6 does; It's not about the TB, lid, or MAF size. It's about flow. I hit my #'s with an SLP lid and stock MAF, the so called "choke points" you're referencing.
My cam is smaller than the ones you're looking at as well...
Mike really knows his ****. That's real talk. If I was you I'd call him and explain your goals for the car. Let him help you get there. One stop shopping is always a bonus in the long run.
Quick Reply: Low LSA cam question
