LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   New LS1 Owners - Newbie Tech (https://ls1tech.com/forums/new-ls1-owners-newbie-tech-4/)
-   -   Ls2 engine swap won't start (https://ls1tech.com/forums/new-ls1-owners-newbie-tech/1632132-ls2-engine-swap-wont-start.html)
Magicman33 Mar 18, 2013 10:47 PM
Please help.
I installed 05 gto ls2 into my 1967 Camaro convertible. I used the gm performance wiring kit with there computer. I had a local machine shop change the 24 tooth reluctor wheel to a 58 tooth. I also changed the crank and cam sensors to grey sensors. Just found out that the upper timing gear was different so I changed it from a 1x to a 4x gear. I can not get it to run. I have good fuel pressure and spark. It seems as if the timing is off. I am getting worried that the machine shop put the reluctor wheel on wrong. Any ideas or thoughts would be greatly appreciated.
sabastian458 Mar 19, 2013 01:36 PM
Sometimes those wiring harnesses for the cam sensor have the wires crossed.
© 2026 MH Sub I, LLC dba Internet Brands
