Had clutch replaced with machined flywheel, but now car vibrates!!!
Just had my car worked on here at my job at a high end dealership, clutch and then had the reae main seal leak fixed, but now i got the entire car vibrating!!! Any advice or ideas, car is a 01 ss with Ls7 clutch, headers, dyno tuned.
Possibly the pressure plate bolts not torqued properly could cause the vibrations.
Have you eliminated easy stuff like they accidentally knocked off a plug wire or induced a miss in the engine by any other means? Knocked a hose off causing a vacuum leak? A dead miss will cause vibration and plugging things back in is pretty cheap! Broke a motor mount or trans mount? Trans mount is notorious for failure on those and not bad. Motors mounts I have heard are a real b/tch.
Pilot bearing would cause some noise when the clutch is disengaged but I can't imagine it causing vibration when the clutch is engaged(clutch pedal "out") because at that point the engine and transmission input shaft are turning the exact same speed..the pilot bearing/bushing isn't doing a thing at that point.
OP, you say it "vibrates, period." It occurs to me that if the clutch is causing this it is due to it rotating and being out of balance due to some kind of issue similar to what you mentioned..but this would change with RPM. Out of balance at idle may cause some vibration but that same vibration should be a lot worse or at least different at 3000RPM. So please do some homework and give us better info so we can help you.
Better yet, post a video of the issue at different RPMs with clutch in and out.
Yes it gets worse, sorry about being veg but yes gets worse at higher rpm. I've heard pilot bearin, but i didn't have any issues before bringing the car in but afterwards, this all happened.
I was confused when you mentioned "machined flywheel" and LS7 clutch at first. That's why I first asked what flywheel you had, because I don't know how you would machine an LS7 flywheel. Just assumed you installed a brand new LS7 flywheel and clutch set. Why was the LS7 flywheel machined to begin with and who did it?
My wonderful ppl here at my job, told me to have it machined then after they did the research, which i should have done, they tell me, oh, you weren't supposed to have it machined...go figure,ill never take my car here again...lesson learned.
At the end of the day, you got the problem solved. Good deal.
