LS1-LS6 advise
Old 02-16-2015, 12:42 AM
Bohnseye's Avatar
Thumbs up LS1-LS6 advise
In the process of doing an LS6 intake swap on my 98 LS1. Only upgrades on motor are a catback exhaust, SLP cold air kit and a polished TB. I was told it had a custom tune when I bought it. It is a low mileage car and runs well. My question is will I need to do a tune if im only swapping intakes? And if yes which tuner do you guys recommend? I don't want to go backwards in performance. If read a lot about intake swaps but nothing has been said about needing to do a tune. Thanks guys..... really appreciate your knowledge.
Old 02-16-2015, 02:26 AM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,459 Likes on 1,052 Posts
In terms of driveability and performance, there is no tuning "requirement" for a simple LS1 to LS6 intake swap. Having said that, if you live in a state with OBD scan emissions testing, then you'll need to consider some sort of basic tune as a requirement to delete the EGR code associated with removal of that system, otherwise you will fail due to the SES light that comes with deleting EGR without a tune.
Old 02-16-2015, 02:35 AM
itsslow98's Avatar
^^ What he said, personally I would wait for more mods like longtubes before bothering with a tune.
Old 02-16-2015, 02:39 AM
Bohnseye's Avatar
Default LS! swap
My car already had the egr taken off. No light on now. Previous owner did a tune to turn light off.
Old 02-16-2015, 02:40 AM
Bohnseye's Avatar
Default L1 swap
Will I see any performance at all by just doing swap?
Old 02-16-2015, 02:41 AM
Bohnseye's Avatar
Default LS1 swap
And by the way..thanks guys
Old 02-16-2015, 04:21 AM
itsslow98's Avatar
Should be good for aound 10-15hp especially up top.
Old 02-16-2015, 12:48 PM
RPM WS6's Avatar
Small gains at best. The intake swap isn't worth much on a stock engine with stock exhaust manifolds, but as you do more modifications the LS6 intake will better support them vs. the LS1 intake.
Old 02-16-2015, 04:17 PM
Bohnseye's Avatar
Default Ls1-LS6 swap
Going to put a Comp HR265HR cam and long tube headers. That with the LS6 intake. They are going to upgrade my springs. So I hope I can get away with stock heads. Would really appreciate any more advice.
Any advice would be appreciated
Thank you guys very much
Quick Reply: LS1-LS6 advise
