427 stroked questions
Guys I wanna build a motor that will be n/a in the beginning but take a magnacharger in the future. I want it to be around 550-600 hp at the wheels n/a and at least 1000 hp with the magnacharger. I also wanted to know if I can get to a 427 with a 6.0 cast iron block as a starting point? What heads will be the best option for both goals and what company sells the kit needed. Thanks in advance guys.
I would start with a 5.3 aluminum block or a LS2 block then install darton sleeves as mentioned above. The darton sleeves are better on stability and reliability as far as long strokes go. I would do a no more than 4.0 stroke in a factory sleeve/bore block.
These sound like a great idea but aren't really in my budget. I want to start off with a cast iron 6.0 because sleeving is not needed and the blocks are strong. This is going in s classic, weight saving is not really a concern of mines. Building the most reliable cost effective motor that matches my criteria is paramount. If I need to go 408 instead of 427 maybe that needs to be a consideration but I don't understand why I can't do a cast Iron 427 striker.
I'll definitely go the 408ci route then!!
