150 shot for $100
150 shot for $100
i would research this myself but this guy i know called and said he has a 150 shot of n2o that he would give me for 100. He said that he woud give me about an hour to think about it because he can get a lot more on ebay. I was thinking $100 that not bad but would this be too much for my car. If so how much would it cost to bring it down to a shot that i could use?
its a dry kit.
its a dry kit.
i'm not 100% sure, i would double check in the Nitros Oxide section, but i've heard that a 150 shot should be ok. I would jump on it. If anything doesn't work sell it on ebay. or to me
You should be able to buy different jets to take it down to about a 100 shot, just to be safe, if you want. New jets are not very $$$. $100?? **** man it's probably worth a shot, lol. You have any reason not to trust the guy?? I'd buy it...... A 150 on most stock cars is pushing it......except on 98's cause they have higher rate fuel injectors
Hes a good friend thats why he offered it to me so cheap. I just didnt want take it if i could use it for the same reason that we are good friends.
Thanks tho i believe i do want it.
Originally Posted by Guy2626c
If i remember correctly in either 2001 or 2002 they went back to the higher rate injectors. So you should be fine.
Originally Posted by Tiger2o69
blkZ28spt,
How is ur rear end holding up w/ the drags and converter? Have you been running that setup long?
I wish i knew someone who was a nitrous kit for $100 Let us know how it works out and how much you gain.
Sure thing, will let u know when i get it installed. I plan to run the tci 3500 w/ nittos also, but I road race alot so i dont know how long mine will last. The track is too far away for me to go a lot so ill prolly only go 2 or 3 times. Thanks for the info.
