fpr help please
fpr help please
I, all new to the forum. been searching for weeks. here is my ?
I have a 1999 T/A , the fpr is in the tank . I noticed the old one does not have a vacuum line attached the 90 degree bend is just vertical. It is original I think should there be a line attached or not ,there is no line in the tank or anywhere on the assembly. thanks for ant help.
Hard start issue O2 sensor code po157
For those of you with a 98 Trans Am and newer a fuel pressure regulator will be in the tank no but I went ahead and just rebuild it put it back in through it over the weekend everything back to normal once you put the fpr back in it doesn't have a vacuum line to it no codes starts right up runs smooth and great so if you have a hard start on a stone oh to code you might want to just do a pressure check on your fpr and if you find out it's bad just drop the tank and put a new one in system is all good
