Fuel pressure issue
Fuel pressure issue
Hello I'm new to site just created a account to hopefully get some help with a fuel pressure issue I'm going through, my car is a 1998 camaro 5.7, I replaced knock sensors, oil pressure sensor, cam position sensor and intake gaskets, torqued everything to spec went to start car and it just cranks checked fuel pressure 0 psi checked fuse and relay both good could not hear pump come on either, so I pulled the fuel pump plug and checked for power with test light light comes on when key cycles forward so I put a new fuel pump in pump made normal noises, car almost started and now pump is putting out 0 psi again and is not humming or making noise I'm stumped with this issue, would the VATS affect the pump at all I was having issues with that awhile back but now vats is working fine, new pump bad ? Any info would help thanks guys
