LS1 370 stroker rebuild
Trash has gotten into the motor from the dip stick not properly sealing. Also I had bad wiring to a fuel injector and the #3 cylinder was running cold for a long time. I want to tear it completely down and rebuild this motor back up to its potential. What would be a good strategy and parts list to gather in order to complete a thorough rebuild? Thank you for you time.
Engine valley cover with the updated PCV, LS7 lifters, push rods, Cam, BTR Valve Springs, C5R Timing Chain, meiling oil pump, arp rod bolts, studs, forged pistons, cnc the heads, forged crank, Head Gaskets, new dipstick and oil ring, Driven Breakin Oil hope this helps good luck
