LS1 power way down
LS1 power way down
Did a dyno pull on my LS1 transplant 177RWP! Engine stops pulling about 4K RPM...we have the MAF only a few inches from throttle body, going to move it out, had to take the timing down to 18 degrees to stop the detonation.. Stock engine with roller rockers and headers. Ideas?
im no mechanic so just an idea. after my heads , cam & intake install my can ran in limp mode due to a teeny tiny wire off the back of the intake to the computer was broken. i was throwing a low manifold pressure code i believe. goodluck!
My SLP under drive pulley was bad and made my 99 Z see knock about 4200 rpm, took several years and lotsa money to figure this out, went back to stock and it pulled straight to redline with no issues. The Killer was it would throw no codes, Good Luck
