Hi Altitude driving / tuning?
if living and working in a town at about 7000ft and taking weekend trips down to lower elevations would it be best to leave a car NA or could I run a supercharger with no adverse effects? my biggest concern would be the tuning on whether or not the computer would adjust accordingly to the air pressure changes.
I used to live in Colorado (Denver and CO Springs) which was approximately 6000 ft elevation. I would make a trip to Nebraska couple times a year (approx. 1300ft elevation) on my motorcycle. I had a wideband datalogger and was able to view the AFR. Definitely a huge change, coming off the mountain (or 6k foothills) and also going back up. I used to have to stop and load in a new map.
You would need two tunes, then load them accordingly. Easy to do with laptop on board, or perhaps a handheld tuner.
this is how I should have written my question..
There is a good chance I'll be moving to Northern New Mexico. elevation: 7000+ft. My question for when I get another LS Firehawk or a C6 mostly for daily driving with lower elevation changes and looking for 500+'ish-rwhp. Could I do a Supercharger or turbo with one tune? or sacrificing the desired 500+, Would a heads and cam job be more recommend for at least a little more power then stock?
BARO Comp
Hi Hawk, I manufacture engine controls that some use in BAJA "off road" races. (desert)
These races start at sea level go to 10K feet, then end in Reno, NV.
I fit a MAP and BARO sensor on the ECU. (internal)
The OEM GM calibrations are tested at ALL Altitudes in the USA.
They too have BARO correction mainly by MAF and a BARO sensor.
Your first question : At 7K feet the supercharged engine would work much better than a N/A engine.
What boost PSI would you run ?
Lance
Lance
Lance
Lance
yeeeeeahhhh... this is a dead topic (maybe useful to someone else though(?) . I talked to the guy who built my turbo'ed hawk and he said the same thing. That car was running the oem MAF and tuned for WOT at 20psi but was only running about 10 until I got used to the power so it ran a bit richer. good times! Now hopefully I land the job!
