My first F-body, what to look for? - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 11-12-2017, 09:43 PM
Default My first F-body, what to look for?
hey guys, I just bought my first f-body, a 01 Z28 A4. Has 142000 on it all stock except for a flow master muffler. Any things I should look for in these cars?
Willis454 is offline
Old 11-14-2017, 11:11 AM
Make sure there are no leaks, lighting problems not sure if the camaros are as bad as my trans am. Should be a great car if it was took care of.
BabyPye is offline
Old 11-14-2017, 06:20 PM
Sail Panel bubbling paint, tail lights leak water, electric window motors, "T" top leaks. Just a few annoyances I can think of off the top of my head. GREAT cars! Just keep up with the maintenance.
cookseyb is offline
Old 11-14-2017, 07:05 PM
Originally Posted by cookseyb View Post
Sail Panel bubbling paint [...]
Good luck at fixing that if he has that problem. No new ones out there. Really sucks because I can see issues with mine if looking at it in the right angle, so I've parked the car from daily driving. I'm on panel number four. I wish GM would produce a batch of them; I'd purchase three of them.
2002 SS #476 is offline
Old 11-21-2017, 02:49 PM
5.7stroker's Avatar
repaint?
5.7stroker is offline
Old 11-22-2017, 09:40 AM
Definitely make sure your T-top seals are in good condition. My old 01 Z28 used to leak bad. Rubbing vaseline on them every week helped the leaking.
Slow-WS6 is offline
Old 11-22-2017, 12:21 PM
LS1Tech Administrator
RPM WS6's Avatar
Why so many panels? All it takes is proper underside prep and they will last indefinitely - just like the '93 to mid-'98 cars did from the factory. I had the panel replaced on my '02 back in '07 with a new OEM unit following the TSB directions and the panel was still perfect as of a couple years ago when I sold the car. It was daily driven and parked outside almost exclusively during that period as well.
Originally Posted by 5.7stroker View Post
repaint?
Not an option, the issue will simply return. If you have a '99+ 4th gen (or a very late '98) then the roof will need to be replaced to properly correct this problem. Here's a link to further details:
https://ls1tech.com/forums/paint-bod...e-dummies.html
RPM WS6 is offline
Old 11-22-2017, 10:36 PM
Wow this is very disheartening...........I noticed a small bubble on my 30th today
JCS30TH is offline
Old 11-22-2017, 10:44 PM
98CayenneT/A's Avatar
If you look at the bottom of the front fenders and they stick out a little further than your door panels it's because some dim wits think it's fine to lift them by the pinch rail which ends up folding over and pushing the bottom of the fender out. You can suck it back in by gently straightening the pinch rail back out.
98CayenneT/A is offline
Old 11-24-2017, 10:56 PM
Throw some bolt on Subframe connectors underneath the car do to the unibody you can actually flex these cars and then the body panels wont line up like the fender and door you'll actually see a gap
Guuseppe'sTA is offline
Old 11-25-2017, 12:34 AM
RPM WS6's Avatar
Chassis flex is not the reason for the gap, the actual reason was already covered by 98CayenneT/A in his post above:
RPM WS6 is offline
Old 11-25-2017, 12:42 AM
My fault your right I had a nice set of BMR 4 point subframe connectors bolted in and I just feel like its a nice insurance for when you make future power.
Old 11-26-2017, 11:31 PM
Thanks guys, I'm a paint and body guy, so I'm not too worried about the cosmetic stuff, it does seem to have a small oil leak from the rear of the engine. Drips on front left cat while running. Not sure if this is a easy fix or if the dreaded rear main leak is starting. Either way the car is very clean and I'm excited to finally have a ls1 powered F-body.
Old 11-26-2017, 11:32 PM
Quick question though, how do I enable the third party deal on here to be able to see more pics. I'm trying to find a picture of an orange camaro with deep dish c6 z06 wheels.
Old 11-27-2017, 04:24 AM
RPM WS6's Avatar
Those roof panels are still pretty expensive, even if you do all the labor yourself. Getting some of them to fit right might take some work but, if you happen to be a fiberglass specialist, you'd also have the option of fabricating a custom replacement panel.
This isn't much of a concern with an auto car, unless the leak is so bad that you're adding oil constantly. It's a bigger deal with the manuals since the oil can work its way to the clutch. I didn't bother to ever fix this on my '02 A4 car, it never left more than a few drips here and there; didn't get any worse even after several years and wasn't worth the cost or hassle to repair.
RPM WS6 is offline
Old 12-05-2017, 08:47 AM
Originally Posted by willis454 View Post
hey guys, i just bought my first f-body, a 01 z28 a4. Has 142000 on it all stock except for a flow master muffler. Any things i should look for in these cars?
everything!
RockinWs6 is offline
Old 12-05-2017, 10:48 PM
Number Tew's Avatar
The old plagues everyone always jokes about:
Window motors
Cracked door panels and dash boards
Changing spark plugs (just changed them - PO changed 1-7 but left 8 OEM because they are babies!)
And as people mentioned the leaky T-Tops and the sail panel issue. If you're lucky your sail panel may have already been fixed!
Number Tew is offline
Old 12-06-2017, 08:17 AM
Crazy idea but do you think it would be possible to 3D Print and clone a Sail Panel while its still on the car? Mine is doing this too and I know removing it usually means completely destroying it.
Need4Camaro is offline
Old 12-06-2017, 10:28 AM
Ls1Ryan2002's Avatar
I used reference to what a member had said when I was looking at my first F Body, found quite a bit of what he said to be the problems, here's what he suggested looking at.
- Differential is very clunky, whiny, and leaky
- Window motors are slow but still functional
- Some minor interior rattles, vibrations, wind noise
- Chrome plating on the wheels is flaking
- Lifter tick
- A/C compressor clutch chatters when A/C is off
- Noise from driver side rear suspension in cold weather
High mileage cars or cars that have been driven hard can have additional problems...
- Oil consumption & or oil leaks
- Worn out shocks
- Leaky t-tops
- Sagging doors
- More interior rattles
- Bubbling (Sail Panel)
- Worn out and exposed seat padding
- Loss of power and fuel economy
- Cracked dash pad
- Original 60e will often slip, specifically the 2nd to 3rd shift, mine started to slip at 79k miles, but I believe the previous owner was very hard on the car.
Overall these cars are great to own, easy and cheap to mod, and have plenty of parts on the market if anything needs replaced. Good luck with your car!
Ls1Ryan2002 is offline
Old 12-06-2017, 11:53 AM
RPM WS6's Avatar
I'm not experienced with 3D printing, but if you're using the original as a template then I would think you'd need to have it off the car to properly capture all the contours/edges. They can be removed in one piece using a wire cutter.
Originally Posted by Ls1Ryan2002 View Post
- Rust (Sail Panel)
There are no issues with rust on the sail panel. The bubbling issue is not rust related nor is the panel able to rust (fiberglass/SMC).
RPM WS6 is offline
Quick Reply: My first F-body, what to look for?
Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
