New to list: Converting 94 GMC1500
Hello, I am new to the list. I operate an auto salvage but I have never salvaged a LT1 or LS1. I am contemplating converting my old 94 GMC1500 xcab (nice old truck) to something MFI with more horsepower and decent MPG for a daily driver. I have even seen posted that a 5.3, which are very plentiful, is a good choice for conversion. I would like to use my transmission and as much of my existing wiring harness as possible.
Any comments or suggestions welcomed.
Randy
Randy
there is no way to keep the wiring harness, on any swap from that old tbi motor you have to use the new stuff, on a truck the swap should not be that hard, you can keep the 700r4 trans in there, for more info on that visit the swap section, a 5.3l would be a great choice.
Being new to the list I cannot find the swap section. Thanks for the response
Randy
Originally Posted by salvageer
Yes sir I undersatnd I will have to change the under hood wiring harness although I would like to retain the underdash harness and use a complete pull-out engine with all accessories (more than likely anyway). I have heard it said that the best and easiest way is to install another computer under the hood to retain the underdash harness. But was wondering if it is possible to plug the new brain into the old underdash harness. I have a 4L60E trans in my truck so I may have to keep the old brain also to make it operate correctly ??? Fabricating brackets or mounts if needed will not be a problem since I am used to doing that.
Randy
Randy
conversion section:
https://ls1tech.com/forums/conversions-swaps-28/
