LQ9 5.3 questions
Old 03-26-2018, 02:29 PM
Switch93's Avatar
Default LQ9 5.3 questions
My friend has a LQ9 5.3 thats been bored out to a 5.7 that im wanting to swap into my jeep.
I'm just trying to get info on the motor.
Anytime i look it up online. I keep getting a LQ9 6.0L
If i get parts for a 6.0L should it fit the 5.3L?
Im new to learning about motors and this will be my first motor swap
Old 03-26-2018, 02:46 PM
ragtopz28's Avatar
What does it say on the back of the block...6.0 (LQ4 or LQ9) or 5.3/4.8 (LM7 or L33)
Old 03-26-2018, 03:38 PM
00pooterSS's Avatar
That's because LQ9's are 6.0 liter motors. There never was a LQ9 5.3
He had a 5.3 bored out to make it a 5.7, he never had an LQ9 and it's still not a LQ9, it's still smaller than an LQ9.
Depends which parts you're looking for but anything but pistons will fit, the 5.3 pistons are 3.78" bore, the 5.7 motor will now have 3.9x" bore and the LQ9 has 4.00" bore
Old 03-26-2018, 09:41 PM
Switch93's Avatar
Thats what I was afraid of.
So first things first. Go see the motor first. (We went to school together he moved) then find out from there. It should have a serial# or a stamp on it though right?
If not how do i find put what 5.3 motor it was?
Old 03-26-2018, 10:06 PM
Lawhead's Avatar
Back of the engine block will literally say 5.3 or 6.0
Old 03-27-2018, 09:19 AM
Switch93's Avatar
Okay. So assuming it's the LM7 or L33 would they be worth building in an
off-road/daily driver jeep?
Old 03-27-2018, 09:45 AM
Lawhead's Avatar
Man I really hate to be “That Guy”
But this has been discussed 1000s of times on mild 4.8/5.3/6.0 builds
Old 03-27-2018, 09:46 AM
ragtopz28's Avatar
Yes, probably one of the most common/popular swapped engine.
Old 03-27-2018, 09:59 AM
Switch93's Avatar
Its all good. I'm new to this forum. I figured it might have been asked somewhere. I haven't found a way to actually search for a thread yet (if you're even able to). But now have an idea on what to look for and areas to find it.
I hate being that guy that beats a dead horse with a stick. lol
Old 03-27-2018, 12:21 PM
00pooterSS's Avatar
It doesn't matter which 5.3 is WAS cause it's a 5.7 now.
You already know everything you need to know, when you go look at it you're gonna see an iron block motor that used to be a 5.3. It won't be aluminum because you can't bore those out to make a 5.7 and it's not a 6.0 because 6.0 cylinders start out larger than a 5.3 bored to a 5.7.
The block will be stamped with either a 4.8 AND 5.3 mark if it was either one. If it was a 6.0 it'll be stamped 6.0. But you already know it was a 5.3 bored out.
ANY of them is worth building in a swap toy, hell even the 4.8 is enough. But seeing as we all always want more the 6.0 would be better but again, even a 4.8 could be plenty of fun. So obviously a 5.7 would also be great too.
GENERALLY SPEAKING the heads, intakes, water pumps, headers, oil pans, oil pumps, cams etc etc etc are swap-able between them all too. There gets to be some things you have to change if you're mixing gen 3 and gen 4 stuff, cathedral port and rectangle port, and mixing 6.0 heads/pistons on smaller motors, but for the most part everything fits everything. Don't run off and just buy random parts based on that statement, it's a general statement to give you the general idea that the blocks and heads etc interchange. Do your research before trying to swap parts because there are a few situations that it won't work unless you adapt something.
Old 04-02-2018, 09:57 PM
dawgs74's Avatar
Yea these guys can be harsh on about the dumbest questions. ........but knowing is half the battle, I get **** all the time but only way to learn is to ask....you'll get there!!!!!!
