Oil pressure gauge
Oil pressure gauge
I have a '01 z28 camaro with a mild cam and some other minor modifications, the ls1 in it is fairly fresh with about 4k miles on it since rebuild. I used to get 60-65 pound of oil pressure off a cold start and always over 40 pounds when warm. Then one day i noticed it a little lower than usual but i didnt think anything of it and every day it seemed to get lower. Sometimes when starting it up now the gauge doesn't even read anything and ill get the "check gauges" warning light then it jumps up to around 40 then drops off to maybe 15-20 when warm. I know the oil pressure gauges in these things kinda suck and the car runs great so i doubt it spun a bearing or something internal. I'm just curious if anyone knows a way to get the gauge working properly without putting a new cluster in it.
LS1Tech Administrator
Received 1,468 Likes
Have you tried replacing the sending unit?
Originally Posted by ragtopz28
Not really with the correct socket. Remove coil pack for more clearance.
10-4, I just didn't know if you wanted to drive around another month or so not knowing why/if low oil pressure.
Dropping it out the bottom I assume?
My 1998 WS6 A4 jumps around quite a bit at times, but the fact that you get CONSISTENTLY low pressure concerns me. If you're sure it's fine, good. Just be aware that in my 1997 Firebird V6 with the 3800 II, my oil gauge started to do that and I literally took out bearings like you said. But as long as you're good, cool.
