DBW throttle body
DBW throttle body
Hello , I have a LQ9 out of a 04 Cadillac Escalade , I put a LS6 intake and injectors on it , also a corvette water pump , My problem , the intake seems to set to low for
my original DBW throttle body to fit , the bottom of the TB is hitting the top of the water pump , what has been the normal solution to correct this ? , I started grinding the
bottom of the TB where the coolant tube goes through , ( I think it is a coolant tube ) but hate to grind thru . Do you grind this until it fits , or is there another compatible
TB I could use ?
Any and all advise will be greatly appreciated .
TB I could use ?
I got it to fit today , got impatient as I always do , took my die grinder with a carbide mill cutter to it , it fits pretty good , I can just slip a piece of paper between the TB and water pump , mission accomplished , thanks for your input .
Vern
Vern
