Terrible grinding when attempting to start
Hi everyone,
Looking for help, I have a 98 Trans Am LS1 automatic with 85K that I've owned for a little over a year. As the title implies, when I go to start it, the starter just grinds and does not turn over at all. It sounds like a grind similar to if you tried to start it while it's already running.
Does anyone have any experience with this issue? I haven't had any starting issues with this car before. I tried jumping it today to see if it was a weak battery issue, but nothing improved.
Any help is appreciated, thanks!
Update
UPDATE: 1/27/19
After taking out the old starter, it was found the mounting point of the starter to the block was cracked, causing the starter to misaligne. The block is fine, flexplate does not seem to be missing teeth. A new starter was put in, turn the key, clunk. It's no longer grinking, but now the starter can't turn the motor, which may be why the starter broke to begin with. The motor turns to a point when manually rotating the crankshaft, but then will not continue to rotate.
Is it hydrolocked? Or do you think there's a stuck pully that's not enabling the motor to rotate?
Always start with removing the belt and turning it by hand. A seized ac compressor with a strong belt can stop an engine quick.
