Thermostat Recommendation
Old 05-19-2019, 12:58 PM
JTB
JTB's Avatar
Default Thermostat Recommendation
Hi. Can anyone tell me the recommended thermostat temp for an LS1? Mine actually came without a themostat in it and I was going to put a 190 degree thermostat in but a friend said I should put in a 160 because I live in a hot climate. Any thoughts? Thanks!
Old 05-19-2019, 01:36 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,458 Likes on 1,051 Posts
LS1s originally came with 86°C (187°F) T-stats.
Personally, I'm not a fan of the 160° T-stats for the vast majority of LS1 applications. I would either stick with stock or (since you don't have the stock one anyway) do a 180° if you want one that's slightly cooler.
Old 05-20-2019, 02:41 AM
sjsingle1's Avatar
I have used a 160 stat from day one.......get a LT1 rad too and you are set
Old 05-23-2019, 07:28 AM
Matt_ws6's Avatar
I agree with RPM, stock or 180. I still have the stock one and never have had any problems.
Old 05-23-2019, 02:50 PM
SouthernRex's Avatar
If overheating is a problem (it shouldn't be, I live in a very hot state), the stock thermostat won't be your problem. You want the thermostat to do its job and get your car up to operating temperature so the metals can expand and the oils to become the correct viscosity. You could always have a tuner lower the temperature at which your fans start spinning if you wanted.
Old 05-23-2019, 02:52 PM
Chris25's Avatar
Id put the 160 in it. I've ran em in multiple LS cars in Florida cars always stay nice and cool.
