Newbie Starting From Scratch - Battery wiring?
The roller I bought was missing the battery cables. The motor is in the car now. I bought some from AutoZone and have ran a positive from the battery to the starter. I have the ground from the wiring harness on the starter as well. I ran a negative from the battery to the engine. I then ran a temp wire from the positive battery terminal to the fusebox post on the driver side. I have a "service engine soon" light on the dash so that's progress, but I am thinking I should be seeing a lot more. I have attached all misc. grounds I can find. Two on passenger side by battery, 3 behind the engine attached to the block, and a couple other misc. ones.
Could anyone help me out? I know it's extremely broad and not an easy task probably but hoping I can get it done.
The following users liked this post:
B52bombardier1 (03-19-2020)
Regaring battery wires, you should have:
B+ to starter
B+ to alternator
B+ to power dist. block
B- to chassis
B- to engine block
Ground from engine to chassis
B+ to starter
B+ to alternator
B- to chassis
B- to engine block
