1998 camaro ls1
1998 camaro ls1
I'm considering purchasing a camaro 98 and I am wondering the best and cheapest ways I can increase HP to that sucker. What suggestions do you guys have?
Heads
Intake
Valvetrain
Exhaust
KILLER BEE!
Intake
Valvetrain
Exhaust
KILLER BEE!
BTW
Horsepower is not cheap!
Cylinder heads: Stock 243, 799 or 317's $300-$600 range. Getting them CNC ported and having them outfitted with some stainless steel valves will set you back another $1500 so your about 2G into a set of heads.
Intake manifold: LS6 intake $200-$300 or go for a FAST 92 with 92MM throttle body for $1200 or find it used for less
Cam, springs, lifters, pushrods and some rocker arm trunnions for the stock rocker arms will be in the $700-$1000 range and if go with some aftermarket aluminum roller rockers add anywhere from $700-$1300
1 7/8" long tubes: $600-$1200 for decent ones or you can buy some cheap ones $200-$400
So as you can see it adds up real quick and you haven't even been into the bottom end of the engine or accounted for the labor involved for the installation. You may have to upgrade your fuel system too and of course the cost for getting it tuned. Is this a manual or an automatic?
LS1Tech Administrator
Received 1,800 Likes
Pontiacerator
Making big power is one thing, getting it to the ground effectively is another. Your drivetrain, suspension, and tires will need substantial upgrades to be up to the task. And what you do in those respects is dependent on your goals for the USE of the car.
The following 2 users liked this post by RevGTO:
cookseyb (03-20-2020), Tyler Dietzenbach (03-17-2020)
Nitrous best bang for the buck. And more power than any heads cam kit. Also easier and less work to do no major engine tear down. 100 shot wet kit pretty safe even 150 shot pretty safe.
