New to 6.0
New to 6.0
Ok here is a list of what i have and a few questions. Any help are good advice appreciated! I have a 2004 lq4 6.0 my plan is to install a texas speed
231-234-108 cam and a set of 243 heads with springs and pushrods to support it. Question 1 the heads are milled .20 .will there be a clearance issue to run flat top wiesco pistons? Also if milled .30? I plan to use stock mls gaskets. Running a 350 turbo 3200 stall and 373 gears
dont know where to post ,was just looking for some advice . If its in wrong section i truly apologize,just thought maybe someone would offer some advice. Guess not
No, you won't have clearance issues.
Also, you can get some gen 4 6.0 rods and pistons (or LQ9) for $150-200 shipped and avoid having to spend money on Wiseco flat tops with are absolutely not needed for an N/A build.
It depends how much ptv clearance you find acceptable.
There is no proper way around other than checking for yourself
