help!!!!! PCV tube replacement 02 Z28
All right--anyone replace the PCV tubing section on their camaro??
Is there room to remove the drivers side valve cover "fitting" without removing the AIR diverter valve?
My fingers tell me NO- and having great difficulty getting at the rear mount for the diverter valve
Dont want to get it stuck 1/2 out!
(PS went to the local library for gm tech notes-no help-did see on an estimator-said labor for this job is .4 hrs!)
it takes that long to see it lol
any help greatly appreciated
It's this PCV line right here that branches off to the rear port of the passenger side valve cover. You can always use a 3/8" T for that connection if the factory one breaks and connect the hard plastic lines with short peices of 3/8" rubber hose if you had to go that route.
P.S. Love the Monte!!
Been a whice since I've seen the AIR in one but I know what you mean. Might have to come off.
Thanks, built that SS a long time ago, ironically after my 1998 SS Clone wrecked because I wanted to get out of a 4th Gen Fbody and have Engine Bay room.
Build thread in the signature with detailed pics. Yea that car will spoil you with having room..
https://ls1tech.com/forums/conversio...t56-build.html
