LS1 Part Numbers.... (searched)
On my floor is a bare LS1 block/heads/crank and I am a new Ls1 owner so....
I've searched everywhere including calling GM. But does anyone know where I can find a complete list of LS1 engine part numbers... things like exploded diagrams and technical specs. You know a book of nothing but LS1. Part numbers being the most important.
Thanks in advance for any assistance you can offer.... my search so far has been nothing but ,.
Moderator
If you go on eBay you will find people selling CDs with
the GM parts manuals on them. These appear to be
microfiche rip-offs, turned into .pdf files. I bought
Camaro & Firebird ones, they're cheap (but the guy
I got them from, laid a file lock / password on mine,
pretty cute for something that's obviously copyright-
stolen from somewhere else).
If anybody happens to be able to unlock and edit huge
PDF files, so as to remove any traceability back to me,
I would have no problem "setting it free in the wild".
The freebie crackers I have found, choke (or balk) on
the size.
the size.
the size.
the size.
How big is the file? What do you need edited? PM me with specifics.
Originally Posted by jrp
i have those same locked .pdf files bought of off ebay.
which things are you specifically looking for 87f383?
acctually all of them. I found a place w/ a large 1400 pg. pdf. But the part number for the pistons is wrong and I can't find a part number for a complete gasket set. Do you by chance no either of those?
SN95 Director
PISTONS
88984245 Piston Assembly, 1997-03 --
This piston assembly is used on all 1997-2003 production Corvettes and Camaros.
PISTON RINGS
88958601 Ring, Piston Gen 3 (Std) Unfiled Gaps --
Identical to the production LS6 ring pack except the end gaps are unfiled, which allows engine builders to optimize ring gaps for competition applications. The second ring is a Napier type ring, which controls oil as well as being a compression ring. The oil rail expander ring is also revised for improved oil control. Can be used in any Gen 3 type engine. Each ring set does one cylinder of a Gen 3 engine.
88958610 Ring, Piston Gen 3 (+.010) Unfiled Gaps --
Identical to the production LS6 ring pack except the end gaps are unfiled, which allows engine builders to optimize ring gaps for competition applications. The second ring is a Napier type ring, which controls oil as well as being a compression ring. The oil rail expander ring is also revised for improved oil control. Can be used in any “Gen 3" type engine. Each ring set does one cylinder of a Gen 3 engine.
Technical Notes: Use with .010 over-bored cylinders.
what gaskets are you looking for?
PISTON RINGS
SN95 Director
HEADER FLANGES
12480130 Header Flange, LS1 or LS6 (Pic)
These steel header flanges are a great way to start a fabricated set of Gen 3 headers for a race car or street rod. This flange is for stock exhaust port location.
OIL PANS
12561828 Oil Pan, 2002-03 LS6 Corvette --
This oil pan is used on 2002-03 Corvettes with RPO LS6.
CYLINDER HEAD GASKETS
12498543 Cylinder Head Gasket Kit “1997-2001” --
This gasket kit includes two head gaskets for 1997 through 2001. LS1 Camaro and Corvette, plus 1991 Corvette LS6 engines.
12498544 Cylinder Head Gasket Kit “2002-2004” --
This gasket kit includes two head gaskets for 2002 through 2004 LS1 Camaro and Corvette.
CYLINDER HEAD VALVES
12565311 Intake Valve --
LS6 hollow stem intake valve. Used with P/N 88598606 roller camshaft.
12565312 Exhaust Valve --
LS6 hollow stem, sodium filled, exhaust valve. Used with P/N 88598606 roller camshaft.
CYLINDER HEAD VALVE SPRINGS
12565313 Valve Spring --
LS6 valve spring. Used with P/N 88598606 roller camshaft.
12565117 Valve Spring --
LS6 valve spring. Used with P/N 12480033 “Gen 3” Hot Cam.
VALVE COVERS
12480025 Gen 3 valve cover. --
This magnesium valve cover can only be used on the discontinued racing cylinder head P/N 12480005 or racing cylinder head P/N 12480090.
Technical Note: This valve cover will not fit LS1, LS6, or LQ4 production heads.
CYLINDER HEAD BOLTS
12498545 Cylinder Head Bolt Kit “1997-2004” --
This bolt kit includes fifteen head bolts for 1997 through 2004 LS1 Camaros and Corvettes and LS6 Corvettes. This kit services one head only. Two are required per engine.
Technical Note: Head bolts cannot be reused on these engines.
TIMING CHAIN DAMPERS
88958607 Timing Chain Damper, LS1, LS6 --
This timing chain damper is intended for high engine speed applications and is used to improve timing chain life. Some blocks require drilling and taping - an instruction sheet is included.
TIMING CHAINS
88958608 Timing Chain Heavy Duty, 1997-03 --
This is a heavy duty single roller chain that uses thicker alloy steel sideplates to improve strength. It is a must for high performance Gen 3 engines.
TIMING RINGS
12559353 Timing Ring, Crankshaft Trigger --
This timing wheel is used on all Gen 3 LS1 and LS6 engines.
CRANKSHAFTS
12559354 Crankshaft Assembly, 1996-03 --
This crankshaft assembly is used on all 1997-2003 production Corvettes and Camaros. This is a nodular cast crankshaft with casting P/N 12552216.
CONNECTING RODS
12568734 Rod, Connecting, 1997-03 --
This connecting rod is used on all 1997-2003 production Corvettes and Camaros.
Technical Notes: Use with 12568069 LS6 Connecting Rod Bolts
CONNECTING ROD BOLTS
12568069 - LS6 Connecting Rod Bolts --
These rod bolts have increased strength over all pre-2000 model year “Gen 3 rod” bolts. Recommended for use in all performance “Gen 3” engines.
INTAKE MAINIFOLDS
88894339 Manifold, Intake --
This is the Gen 3 fuel injection manifold used on 2001-03 RPO LS6 Corvette engines. The manifold includes the manifold, intake manifold seal P/N 12560251, intake manifold gasket P/N 12533587, throttle body seal P/N 12552542, map sensor P/N 16212460, map sensor seal P/N 16194007. [Old P/N 88890523]
INTAKE MANIFOLD GASKETS
12533587 Intake Manifold Gasket --
THROTTLE BODY SEALS
12552542 Throttle Body Seal --
MAP SENSORS
16212460 Map Sensor --
MAP SENSOR SEALS
16194007 Map Sensor Seal
OIL PANS
VALVE COVERS
CYLINDER HEAD BOLTS
TIMING CHAINS
TIMING RINGS
CRANKSHAFTS
CONNECTING RODS
INTAKE MAINIFOLDS
THROTTLE BODY SEALS
MAP SENSORS
MAP SENSOR SEALS
Thanks for those piston part numbers and the seals, not nearly as many gaskets as I thought there were gonna be. And I guess at the price the pistons go for on GMpartsdirect, I might as well step up to some forged ones for only $100 more. I think new stock rods w/ arp fasteners will hold up to my power goal easy enough. Just a cam (230/224 .575/.563 111 LSA) headers and possibly a 100shot. Unless I can find some good Aftermarket rods that are cost effective vs. new stock rods. Thank you for your help very much!
Moderator
I found a parts listing on northwest-aero.com that
has the full LS1 crate motor parts list... looks like
good stuff. Do not know which MY crate motor this
is, or how much substitution has gone on, but it is
a nice rollup.
http://www.northwest-aero.com/docume...parts_list.pdf
a nice rollup.
