Under-hood Insulation??
This is from LS1.COM: How to clear the SES by resetting the ECM.
1. Turn key on but don't start car.
2. Pull PCM BAT and PCM IGN fuses in engine compartment.
3. Wait a few minutes.
4. Turn ignition off.
5. Replace fuses.
It also says: 'It will take the car a while to relearn the fuel and timing curves so don't worry about a temporary performance loss.'
5. Replace fuses.
PM me if you want me to take a digital picture of the ones to pull to turn the A.I.R. pump off. I can email it to you. If you're gonna' return the AIR and EGR as stock, don't disable the pump. This is off-topic, but, it's your thread, so, I guess since you're asking it should be OK to answer. PM me if you have further questions and I'll be glad to try and help.
