Request Part Numbers
#203
Originally Posted by Mo6893
I believe the PN# for the LS1 TB gasket is incorrect.
I think this should be: "LS1 stock 75mm throttle body gasket = 12552542"
I got some of those from things other people had posted, as a shortcut to get the ones people liked to ask about, and checked a lot but not all of them...
I suspect that was on an older list that only covered LT1s but didn't specify the items were for LT1s, then someone posted it mixed in with a bunch of LS1 stuff, and I overlooked the mixup.
Thanks for catching that!
#206
Originally Posted by MrEddie
Hi, I searched the list am looking for the following:
2000 Z28 M6:
Lower radiator hose
radiator cap
thermostat
serpentine drive belt
Thanks!
2000 Z28 M6:
Lower radiator hose
radiator cap
thermostat
Thanks!
Rad cap: #10316828
Thermostat with housing: #12571261
Serp belt: 12569527
AC belt: 12569529
Mike
#211
Hi Guys,
I need a few part numbers not listed in the other thread.
Vehicle: 1999 Trans Am WS6, 30th Anniversary, w/ Monsoon Sound, manual transmission. White/Gray 30th Anniversary specific interior colors.
I can PM you my VIN if needed.
1. Power Steering Cooler (Leaking into coolant)
2. Drivers side interior door panel (Cracking)
3. Passenger side interior door panel (Also cracking)
4. Drivers side armrest (Broken fiberglass)
5. Passenger side armrest (Whadd'ya know, also broken)
Thanks a whole bunch!
#213
Originally Posted by LS1MONSTER
manual shifter boot (comes with retainer ring) (97-02) = 10271369
Does this come in only one color? I have the grey interior or whatever its called.
#214
Originally Posted by MetalKnight
Hi Guys,
Here's the only armrest versions I have... if your gray isn't graphite, you'll have to get it from MM98.
armrest (93-02), graphite, RH = 16670348
armrest (93-02), graphite, LH = 16670349
armrest (00-02), ebony, RH = 16638554
armrest (00-02), ebony, LH = 16638555
door trim panel (99, white leather - RPO 105, Monsoon sound - RPO W54/W55), RH = 12456462
door trim panel (99, white leather - RPO 105, Monsoon sound - RPO W54/W55), LH = 12456463
That's the original door panel numbers, but it looks like they've changed, don't know what to.
#215
Need the part numbers for the upper ball joint nut cutter pins and the lower front shock spring perches. Just for clarification, the cotter pins in this pic. Need both the drivers side and passenger side.
http://www.ls1howto.com/howto/fbody/...s/IMAGE003.jpg
The black metal lower spring perch that slides over the shock and sits on the ring around the shock. Here is a pic for reference. Need both the drivers side and passenger side.
http://www.ls1howto.com/howto/fbody/...s/IMAGE011.jpg
#216
front spring seat (93-02) = 22099275
front upper control arm cotter pin (93-02) (0.09375x1.5) = 103376
#217
Originally Posted by ACW
power steering cooler (98-02 with RPO V12) = 10417037
Thanks a lot, I apprecite the effort!
)V(etalKnight
#219
Part number for the small plastic wire clip, or loom, that the abs wire runs through. It inserts into the front lower control arm on both the driver and passenger side. Basically looks like 2 circles with a fastner on the end if that helps.
#220
I was wondering if you could find the part number(s) for the rear compartment trim peice that the speakers go in on both sides.
jack-hole that owned the car before me cut the holes to fix 6x9's in there.
