Request Part Numbers
Old 06-07-2006, 09:33 AM
  #301
mattsls1's Avatar
lol.....
transmission to engine bolts. I think there are 7 (or 8)
Old 06-08-2006, 06:30 AM
  #302
That's MISTER MODERATOR
Paul Bell's Avatar
Hey ACW, thanks for your help!
Whats the number for the rubber flap behind the R/S headlight door? 94 Firebird...
Old 06-08-2006, 08:35 PM
  #303
su_maverick's Avatar
the throttle body bolts for the ls1 came up as wrong part number
Old 06-08-2006, 08:59 PM
  #304
Tydriver's Avatar
Originally Posted by mattsls1
lol.....
Yes !! Please.. I need the bellhousing bolts as well !!
Old 06-08-2006, 09:46 PM
  #305
xthephilx's Avatar
Anyone have the part number for the reverse connector on the transmission? I need the one that's part of the wiring harness (the one that plugs into the transmission, not the thing mounted on the transmission), if it has a separate part number.
Thanks
Old 06-08-2006, 10:08 PM
  #306
ACW
ACW's Avatar
LS1 throttle body bolts (Metric Hex Flanged Head Bolt, m6x1x30) = 11514008
It is not a 'wrong number'. It may have been changed to a different number (which I don't have, sorry), but that is what it was originally.
MM98 should be able to tell you what the current number is.
Old 06-08-2006, 11:59 PM
  #307
ACW
ACW's Avatar
Hrm... I'm not familiar with this flap you're talking about, and I don't see any likely suspects in the diagrams or descriptions.
Is this like a liner on inside of the door lid? If so, it doesn't seem to be offered separately from the door lid itself.
Old 06-09-2006, 01:42 AM
  #308
RedZoutlaw's Avatar
Do you have the part number for the air shroud or baffle, not sure what you call it but its the piece under the airbox that you cut for the FRA mod. Thanks
Old 06-09-2006, 06:52 AM
  #309
mattsls1's Avatar
Anybody know the bellhousing to engine bolts? Should be 7 I believe. Thanks again...
Old 06-09-2006, 03:13 PM
  #310
stangeater99's Avatar
Do you have the part # for the Driver side ground effect?
Old 06-09-2006, 06:48 PM
  #311
MM98's Avatar
Ok here we go, I think this covers it!!!
M6 reverse lock out solenoid pigtail: part#12101857
Yup it changes to part#11516425.
I'm only showing that molding/flap on export models only... Part#10189322
Part#25166571
Part#14050422
Part#12369004
-Mike
Old 06-09-2006, 09:17 PM
  #312
mattsls1's Avatar
you da man
Old 06-10-2006, 05:22 PM
  #313
SS4U2NV's Avatar
Part number for stock torque converter please.
Old 06-10-2006, 06:34 PM
  #314
Thanks bro
Old 06-10-2006, 06:44 PM
  #315
Tydriver's Avatar
you da man
^^ what he said.. Thanks !
Old 06-11-2006, 02:23 AM
  #316
ACW
ACW's Avatar
A4 LS1 torque converter (98-02) = 24210919
Old 06-11-2006, 11:25 AM
  #317
SS4U2NV's Avatar
Thank you for your time
Old 06-14-2006, 02:10 AM
  #318
RedZoutlaw's Avatar
thanks
Old 06-15-2006, 12:19 AM
  #319
RedZoutlaw's Avatar
Quote
Part#25166571
-Mike
The dealership has this listed as a housing at $80. This couldnt be the air baffle could it?
Old 06-15-2006, 12:11 PM
  #320
spy2520's Avatar
part number for battery hold-down bolt please...
Quick Reply: Request Part Numbers
