Help With Modifications!!!
When I had purchased the vehicle, it already had flowmaster exhaust, hooker heads, and k&n intake.
I was trying to supercharge this sucker and wanted to know what are the mods i need to do before I drop a sc in it?
Thanks for all the help!
There are lots of choices, but I guess the main two are the STS rear mount turbo or the ATI procharger supercharger.
All you should need is the complete kit and a tune afterwards and 6-8psi of boost should be fine and good for ~440rwhp.
However in all reality, the Flowmaster is not the best exhaust, as it is restrictive compared to others. With FI it would be well worth swapping it. Also your K&N will go by the way side with FI.
What year car is it? If it's pre 01 then you'll want to get the LS6 intake manifold for it. The 01/2 cars already have it stock. If you're prepared to spend the money on a blower I'd also get your TB ported as well.
Personally I'm not to keen on the STS turbo setup, sure it makes the power and drag strip use will be fine. But I hear too much about LAG and drivebility that personally would not suit me.
I'd go Procharger D1 setup @ 8psi (check the sponsors for prices --->)
With all this power it's also pretty sensible to assume you'll break your 10 bolt rear, so plan on getting a 12 bolt (or equiverlent) in the budget. Even if you don't actually purchase until you 10 bolt gives up.
