Estimate on Cam swap
Old 09-16-2006, 04:32 PM
Ls1Envy's Avatar
Default Estimate on Cam swap
roughly, how much would a DIY Cam swap cost. Excluding a tune.
Old 09-16-2006, 04:46 PM
AFRLS1's Avatar
Figure $400 for the cam $40 for the head gaskets and another $250 for labor
Old 09-16-2006, 05:29 PM
HeapaShifter's Avatar
I might of spent as much as $650. (Camshaft, valve springs, pushrods, timing chain, crank bolt, timing cover gasket, water pump gaskets, oil & coolant.)
I did it all myself. Already had all the tools needed.
P.S. No head gaskets are needed because you don't need to take the heads off.
Old 09-17-2006, 04:32 AM
300bhp/ton's Avatar
depends what cam and what car.
The more agressive the cam the more extra bits you'll need. Springs, push rods, oil pump, head studs, gaskets and such.
TSP, Thunder Racing and similar will sell you a cam and install kit with all you need for a basic cam swap.
If it's just a stock cam or a LS6 cam then you may not need some of the other components.
Old 09-18-2006, 05:37 PM
1sickta's Avatar
don't rush to anything save money and get heads and cam at once, it will save you tuning cost.
Old 09-18-2006, 05:59 PM
Moderator
davered00ss's Avatar
Thunder racing has kits for like $700 I think.
Old 09-18-2006, 06:08 PM
'Trust''s Avatar
You wont really need headstuds on any cam only car, when you do heads etc. its definately something to look into. I say cam cost (I believe comp grinds any cam for $380) + Springs ~$200, $40-$60 for gaskets, thats the bare minimum, then there is what 300bhp/ton said, it goes on and on.
