Any Suggestions On New Ls1 Crate Motor
I have a 98 z28 camaro with a brand new 98 ls1 crate motor with vortech heads and brand new 4l60e transmission I have slp loudmouth catback exhuast pacesetter longtube headers with no cats and an air lid. I also have 18 inch chrome wheels. I have very slow acceleration and only run about a 14.5 at the track. Anyone have any suggestions on what i should do and how much do the big rims slow me down.
Tech Resident
Something isnt right, the rims might slow you down about 1/2 a second at most, but the car is still running slow.
Have you run all the basic mantinence stuff? (plugs, wires, air/fuel filters, ect...). Whats your rear end ratio? What tires are you running?
Any other info you can give us will help. (and welcome to the site)
yes i have ngk plugs msd wires and a new air filter. i think that i ahve 2.73 gears with a steel driveshaft. the tires are not good they are sumitomo 245/40/zr18. ihave rear o2 sensors unplugged ?
sounds like you need the driver mod. What kind of wheels...they coudl slow you down a bit, some cars are factory freaks..some are dissappointments. Between the crappy 2.73 gear and the heavy taller wheels...that could make you run a lot worse, factor in a NORMAL ls1 will trap anywhere from 103-108 usually..then that start to put things in perspective. Also, you didn't mention if your car was tuned, headers are a double edged sword, some cars need to be tuned with them to run not so rich..others run lean. I'd bring it to a shop for a dyno tune...you car could also be sensing know and be pulling a **** load of timing.
edit: just read that you have heads too...did they lower your compression? Could the cam have been knocked off from the original setting?
