Question and Opinions on SLP LT's
Old 12-03-2006, 03:30 AM
SSmoken's Avatar
Default Question and Opinions on SLP LT's
First off will slp lt's with emissions work on my non emissions car??? can i just swap the block off plate or w/e onto these???
Second, found what seems to be a great deal on a set of slp headers and y-pipe, just wondering everyones opinions on them thanks.
Old 12-03-2006, 04:05 AM
tacklebox's Avatar
I've heard the SLP's hang lower and are more prone to getting banged or scraped up. You may be ok if you're not lowered. Block off plates should work.
Old 12-03-2006, 10:07 AM
SSTYCOON's Avatar
I heard there a bitch to install, compare to the other brands, but who knows?
Old 12-03-2006, 10:32 AM
smg267's Avatar
Got them on my car. If you ever plan on lowering it forget it!!!! They hang pretty low less than a fist of clearence. You have to literally crawl over speed bumps. And I just found a new one last night Those gas cap things they fill the tanks with a sunoco. Just wait for the SCRAAAAAAAAAAPE!! All in all they fit in there pretty tight. You need to get a spark plug wire boot to insulate the one Abs wire? You will see it when you put them on. Or it will burn it alive. I got mine for 250 and it was worth it. If I had the money to do it again I would by Kooks they tuck nicer from what i heard. Search the forums for clearence pics.
Old 12-03-2006, 01:06 PM
SSmoken's Avatar
ok thanks guys i'll see if he still has them and try and get them i guess. My car has eibach prokit on it si i guess i'll put the factory springs back on.
