Loss Of Oil Pressure
Old 12-17-2006, 03:03 PM
captain blackbeard's Avatar
Angry Loss Of Oil Pressure
Need help as why my oil pressure dropes when I stop hard, or make hard right and lefts. Ther is a slight ticking and when I turn the car off and let it sit the oil pressure goes back to normal.
Old 12-17-2006, 03:43 PM
02SS#406's Avatar
A little more info might help, like mileage on the car, mods, oil information, etc.
Old 12-17-2006, 03:49 PM
Fiery Features Director
Zangel's Avatar
Did you check to make sure that you are not low on oil?
Old 12-17-2006, 04:01 PM
my car has 117450 miles. The oil level in in the cross hatch. It has 10w30w for oil.
Old 12-17-2006, 04:03 PM
the car is stock for now
Old 12-17-2006, 04:21 PM
BLKWS.6's Avatar
LOW OIL!!!!!! CHECK YOUR DIP STICK ASAP!!!! You should fill it to the middle of the <---- line imho. That is about 6 qts with a standard filter (it shows about 1/2 qt over full, or the tip of the arrow on top). If you are uncomfy with that, just fill it all the way to the tip of the arrow and then when you change oil again put 6 qts in instead of 5.5 (if you do a lot of hard cornering).
Awww ****, thats complicated...time for an illustration. Hold on...
Old 12-17-2006, 04:28 PM
BLKWS.6's Avatar
The middle of the cross hash is only 5 qts and that is LOW LS1's have a front mount pickup tube and DO NOT LIKE!!!! low oil. You should have 6qts or so in that thing and NOT be in the hash area.
^there is a rough guide to how things should look.
Old 12-17-2006, 04:50 PM
i just checked my oil level it is at the top of the crosshatch but it was sitting all night but when i run it it's in the middle. So i should add oil to the top of crosshatch when it is hot?
Old 12-17-2006, 04:53 PM
BLKWS.6's Avatar
go ahead and add about 1/2 qt and see if that solves your problem. Next oil change put 6 qts in it and remember where that level is and maintain.
*that is still not low enough to cause the problem you are having, could something be stopped up pulling oil into the heads while driving? Check your PCV valve too maybe.
Old 12-17-2006, 04:56 PM
Ok i will add a half qt add see if that helps. Thanks for the help
Old 12-17-2006, 05:13 PM
BLKWS.6's Avatar
Sure, I dont think 1/2 qt will be too much at all as you can get away with 6.5qts on a stock filter without hitting the crank, but I say stick with 1/2 qt and dont go over the top of the line that is the end of the "<---" and you should be okay. If this does not fix it, then your issue is deeper.
Old 12-17-2006, 05:31 PM
TAtoad's Avatar
hard stopping, hard cornering makes oil splash around or go to one side of the oil pan, it goes away from the sensor, and you get a low pressure reading. can happen in all cars, just like they say, run enough oil. if you put too much in... it'll just burn, no biggie IMO
Old 12-19-2006, 12:22 PM
BLKWS.6's Avatar
Ummm...no. There is no oil pressure in your oilpan unless you have STOOPID blowby. The oil pressure is not IN your oil pan either.
I am interested to know, did this solve your issue man? or is pressure still being funky?
Old 12-19-2006, 12:27 PM
joes99z's Avatar
the oil sending unit is behind hte intake isn't it?
Old 12-19-2006, 01:16 PM
jmm98LS1's Avatar
^^^Yes....and almost everyone breaks it when swapping intakes lol.
Old 12-19-2006, 11:34 PM
joes99z's Avatar
thats how I know mine was back there cause i broke it hahahaahaha
Old 12-20-2006, 11:59 PM
i add a half qt of oil and have not dropped pressure to 0. I am thinking of replacing the oil pump to a ls6 ported pump.
