Ebay
Also would a 02sensor for 3* bucks on ebay be good? or will both these things be crap?
**EDITED**
Also would a 02sensor for 30 bucks on ebay be good? or will both these things be crap?
slotted rotors shoudl be fine. the integrity of the rotor is not compromised with slots. also dimpled ones should also be fine. look around, theres some good deals to be had.
the rotors by raceconepts; V1specs; rotorworks; brakeconcepts; eliteparts;
Why is irotors better than any of the others?
I honestly think that all these rotors are cheap autoparts rotors that have been drilled and slotted and are now selling for double the price
thanks for the help
(c5 calipers, f-body brackets, rotors, pads)
of yo look at the edge of a rotors, vented ones are two thin rotors that are sandwiched together. the two thin rotors are separated by ribs, this way air can move between the front and back, for better cooling.
when drilled rotors are drilled into those ribs, it hinders the integrity of the rotors, so that under hot situations, the front and back parts can separate in areas, and could either warp the rotor or crack the rotor.
on this one. Too bad, it was so young.
